When exporting to a different folder Psu doesn't recognize the move
Tom Husband
Post by Tom Husband »
When I use the Export to Folder feature (Ctrl + e) in Psu and move images to a new folder Psu doesn't see them. I'll use the function to reduce the size of the images and move them to a new folder all within Psu. I have to scan for missing files and then Psu picks them up.
Re: When exporting to a different folder Psu doesn't recognize the move
Post by snowman1 »
I think that's because export to folder, like share to folder, is meant for transferring [potentially altered, resize being an example] copies of files _outside_ of PSU. So if you wanted them to be in the catalog, additional to the original copies, you will have to do something like this to get them into the catalog. I don't tend to use versioning myself, but sounds like the resize versions should, or usefully could, be held as versions of the originals? I'm sure someone with more knowledge than me can assist with that.
Tom Husband
I'd like to have the exported jpegs in another folder as they are use for a specific purpose.
I tried versioning but I could never really my hands around it. I could continue doing what I'm doing but a few less clicks would be nice.
I thought any moving of files I did within Psu would be tracked?
