Keyword handling problems
Ulrich
Post by Ulrich »
Hi all,
I'm new to Photo Supreme and have quite huge problems with the keyword handling.
Up to now I have used Lightroom for my photo management, but because of RAW development quality reasions reguarding fuji files I changed to Photo Supreme + Capture One. I'm not going to use lightroom in future.
I have imported my former lightroom catalog in Photo Supreme (including all keywords).
My problems are following:
1. Some of my former keywords are shown as categories AND keywords in photo supreme, others are only visible as keywords (in the details page) but not as categories. Why?
2. I deleted some of the keywords, saved the keywords to the file and re-read the keywords from the file. Result: The deleted keywords are there again.
How can I permanently delete some of the keywords?
3. When I select several files (with not 100% identical keywords) the keyword section at the details page is gone, so I can only dete keywords there one by one, which is impossible for many thousand files.
Does anyboady has a hint for me how to get out of this mess?
Is it eventually possible to find a script anywhere which I could customize to delete keywords in several files?
Re: Keyword handling problems
A warm welcome to the forum.
You are missing one crucial part: Catalog Labels.
I assume that you've used the Lightroom Import feature. That means that your keywords from Lightroom are read as Catalog Labels in Photo Supreme. You should understand first that Catalog Labels become your keywords when you write to file. And that keywords become catalog labels when you read from the file (depending on your sync settings, but lets assume you have everything at default there).
That also means that to remove a keyword from an image, you should remove the Catalog Label. In other words, there's no need to edit keywords in the Image Details (you could but then you should know/realize very well how that interacts with Catalog Labels).
I recommend that you also at least skim through the Cataloging Manual.
1) That is correct. Keywords become Catalog Labels (and Catalog labels are in a top level Category like People or Events)
2) Unassign the Catalog Label instead. You can do that in the Label Assignment Panel (click Labels from the command bar below the thumbnails)
3) While you should have no need to edit keywords directly, the following: you can select multiple thumbs and open the Image Details (as you did). With multiple thumbs selected, each editor field gets a command button. Click that button to select what operation should take place. You can choose from "Replace", "Append", "Clear". This applies to every single field, the keywords included.
More questions? Ask!
Ulrich
Post by Ulrich »
Dear Hert,
thank you very much! but indeed, I have to ask again.
Of cause I have read the cataloging manual before I have posted my question.
Possibly I didn't understand everything, but I guess the answer for my problem is not in there.
I tried to describe my problem in detail and with some screenshots.
Therefore I added a PDF with the description and screenshots. Please be so kind and find it in the attachment.
The example foto is there as well.
It would be very kind when you could have a look.
Thanks in advance!
Ulrich
20160409_61_0064-2.xmp
(12.05 KiB) Downloaded 1324 times
ProblemDescription.pdf
(558.98 KiB) Downloaded 1441 times
I have no problem importing the photo; all the catalog labels appear and all can be deleted. Which doesn't help in fixing it, of course...
Can you share a screenshot of your Synchronize settings for Writing (see Preferences). It's this one:
Ulrich
Post by Ulrich »
Sure,
here they are.
Thanks' for your help!
Thank you. That’s what I figured.
You have your write setting config set to “merge”, meaning that catalog labels will be merged with keywords. And so in the end this #4 keywords remains.
Set that to “replace”.
Even better: leave all settings at their default. There’s a button to reset it to default.
Ulrich
Post by Ulrich »
OK, I set everything to the default.
Look good for now!
Thank you for your help! :D
