I shoot RAW+JPG since I moved to a Nikon Z50. The main reason is that I can quickly pull OOC JPGs using SnapBridge for sharing.
I use PSU for ingesting the RAWs from SDcard. I dont ingest the JPGs, and once I've ingested the RAWs I have no reason to keep the JPGs. Can anyone suggest a way I could have PSU automatically delete the JPG as well as the RAW after import?
Thnks,
Steve
Handling RAW + JPG
Re: Handling RAW + JPG
You (or someone else) could write a macro, add it to a batch and run that batch on import (there is a function in import to run a batch).
Personally, i'm not throwing anything away, but then again, i'm weird about that
