PSO - Trial expired message
jgodfrey
Post by jgodfrey »
I just tried to access PSO for the first time in a while and, after signing in, I get a toast message that says my trial has expired. Specifically:
error: Trial expired; Your trial message code <LONG_HEX_CODE>
I re-downloaded from the link found in the opening message to this board thinking maybe you had updated the software, but am still greeted with the same "expired" message. The normal PSU desktop client still works as expected.
Perhaps that's expected at this point in the dev cycle, I'm not sure.
Thoughts?
Jeff
Re: PSO - Trial expired message
Hi Jeff, the beta is trial and works for 30 days. If you post the trial code (it's for your installation only so you can post it here) then I will reset that code for 30 more days
jgodfrey
Post by jgodfrey »
Ah - got it. Thanks Hert. Here's the code:
04FCC5D624B5E80D26221B04D0B8D980
The trial code is reset
jgodfrey
Post by jgodfrey »
Yep, all good now. Thanks Hert.
Username
Post by Username »
Hello Hert
Would you be able to renew my beta as well?
E9B9AE99979E94B8AEA1AAA3B9BAAEA8
PSO 6 on Windows Server 2022
- I'm the user
gcurrie
Post by gcurrie »
Hert:
E6BA9A949692B0ADB5BA9194ACBAAFA4
is expired. Can I get a reset?
Gordon Currie
Photo Supreme 2024 PostgreSQL on Windows Server Essentials 2016
Trial is reset.
Username
Post by Username »
Hello Hert.
My trial ran out again.
- I'm the user
You should be able to use it again
Username
Post by Username »
Thanks Hert.
Worked like a charm
- I'm the user
gcurrie
Post by gcurrie »
is expired. Can I get another reset?
Gordon Currie
It is reset now.
