Batch rename part of filename
peterpix
Post by peterpix »
I've got a lot of files that I batch renamed in the format [ABC]_[yyyy][mm][dd]_[filename] so the current filename is e.g.
I now want to rename these files with different text at the front, e.g.
If I use [Text: DEF_][filename] I will of course get DEF_ABC_20210325_DSF1234.jpg which is not what I want.
Can anyone tell me please how I can batch replace ABC with DEF?
Peter
Windows 10 | Photo Supreme 6 | Affinity Photo | DXO Photolab 5 | Exposure X7 | Capture One 21 | Perfectly Clear | everything Topaz | Luminar 4 | Luminar AI | Photomatix 6 | Aurora HDR | Dynamic Photo HDR
Re: Batch rename part of filename
Use the replace text option. See below.
This is the resulting rename text (which you can copy/paste to the rename dialog after clicking its hamburger -> Edit as Text)
%FileName{replace=ABC_,DEF_}.%FileExtension
peterpix
Post by peterpix »
Astonishingly easy! Thanks Hert for the rapid response.
