preferences window not movable
babarnc
Post by babarnc »
testing v6 I found that the preference window cannot be displaced it is locked to the main window frame
on the attached snapshot you can see that the window does not have its own frame top edge. The grey bar is the top edge of the main window frame
regards
Re: preferences window not movable
Post by weidmic »
Hi babarnc,
this is by design...
babarnc
Post by babarnc »
Ok fine
