Version Set Offset Folder
Dismayed
Post by Dismayed »
I don't think I fully understand the Version Set Offset Folder. I assume that this sets how far in the folder hierarchy to search for matching versions. Does Current restrict the search only to the current folder? Or does it restrict the search to the current level of the hierarchy and leaves? I ask because I do have some photos that do not have unique names (things happen over several decades), so I need to restrict the version search to nearby folders.
~ Will Rogers
Re: Version Set Offset Folder
The "offset folder" is the folder from where PSU starts the version checking.
If you try to detect versions for a file then you can determine the "size" of the set where PSU should find for versions. That "size" of that set is based on the offset folder. PSU will first collection all images from the offset folder, including the files in recursively lower folders. Then for each file in that that set, the quest for versions is started.
Dismayed
Post by Dismayed »
Hert wrote: 25 Feb 21 12:54 The "offset folder" is the folder from where PSU starts the version checking.
Is there a setting that will look at sibling folders, in addition to children?
~ Will Rogers
Then set the Offset Folder to "Parent folder". The parent includes the file's folder and all sibling folders.
Dismayed
Post by Dismayed »
Hert wrote: 25 Feb 21 14:53 Then set the Offset Folder to "Parent folder". The parent includes the file's folder and all sibling folders.
That's what I tried, and I ended up with images in the versions that were children of the root. Not sure why that happened. I had moved a few folder in PSU, so maybe it hadn't caught up when I ran version detection.
~ Will Rogers
