Crash calling Build Missing Thumbnails and Previews
Sigi
Post by Sigi »
Working on my test catalog - around 14000 files in there - if I click on Tools "Build Missing Thumbnails and Previews" I have a crash.
This happens consistently. I am on Mac, Catalaina, all updated.
Sigi
[Edit Hert; updated the topic title to better describe the topic]
Re: V6 - Crash
Is that while building thumbs and previews?
Sigi
Re: Crash calling Build Missing Thumbnails and Previews
Post by Sigi »
yes
Sigi
Post by Sigi »
just updated to the latest build - same problem.
It starts the process and after about 10sec I have a crash.
I'm not having a crash when using Build Missing Thumbs and Previews. Tried on an Intel and an M1 machine, both running macOS 11.2.1.
Also tried on a test machine running Mojave 10.14.6 without issues.
Maybe you can provide additional information? An Apple crash report or a PSU report?
And did you check that if there is sufficient disk space on the system drive?
Sigi
Post by Sigi »
I will send the Apple crash report. Disk space is OK 1.9 TB used of a 3TB fusion drive.
paulrbarnard
Post by paulrbarnard »
Just sent a problem report. I have a similar crash. In my case it is when the verify folder finds catalogue entries for missing files. Selecting to remove the files results in a crash. It might be related as the synchronise process runs which seems to be the trigger for my crash. V6 3556 running on macOS 11.2.1 (Big Sur)
paulrbarnard
OK mine just crashed building thumbnails as well.
crash log
Process: IDimagerSU [52727]
Path: /Applications/Photo Supreme.app/Contents/MacOS/IDimagerSU
Identifier: com.idimager.idimagersu
Version: 6.0.0 (3556)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: IDimagerSU [52727]
User ID: 502
Date/Time: 2021-02-19 16:50:39.755 +0000
OS Version: macOS 11.2 (20D5029f)
Report Version: 12
Bridge OS Version: 3.0 (14Y908)
Anonymous UUID: DFFA8C60-172A-8080-D930-85E5F467FDF7
Sleep/Wake UUID: A4E6E313-A0CD-4B1B-BF9D-F7B4EB33D52F
Time Awake Since Boot: 220000 seconds
Time Since Wake: 1600 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGILL)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Illegal instruction: 4
Termination Reason: Namespace SIGNAL, Code 0x4
Terminating Process: IDimagerSU [52727]
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 com.idimager.idimagersu 0x000000010003dca0 CLASSES$_$TSTRINGS_$__$$_CHECKSPECIALCHARS + 0
1 com.idimager.idimagersu 0x000000010003f4c1 CLASSES$_$TSTRINGS_$__$$_GETTEXTSTR$$ANSISTRING + 105
2 com.idimager.idimagersu 0x000000010055e5f5 UXOMNOTIFIER$_$TXOMSYNCTHREADOBJECT_$__$$__EXECUTE + 469
3 com.idimager.idimagersu 0x0000000100373875 COCOAINT$_$TCOCOAWIDGETSET_$__$$_APPPROCESSMESSAGES + 229
4 com.idimager.idimagersu 0x00000001000641f1 FORMS$_$TAPPLICATION_$__$$_PROCESSMESSAGES + 89
5 com.idimager.idimagersu 0x000000010045d287 TNTFORMS_$$_TNTPROCESSMESSAGES + 31
6 com.idimager.idimagersu 0x000000010055e5f5 UXOMNOTIFIER$_$TXOMSYNCTHREADOBJECT_$__$$__EXECUTE + 469
7 com.idimager.idimagersu 0x0000000100373875 COCOAINT$_$TCOCOAWIDGETSET_$__$$_APPPROCESSMESSAGES + 229
8 com.idimager.idimagersu 0x0000000100066185 FORMS$_$TAPPLICATION_$__$$_HANDLEMESSAGE + 45
9 com.idimager.idimagersu 0x000000010006665f FORMS$_$TAPPLICATION_$__$$_RUNLOOP + 79
10 com.idimager.idimagersu 0x00000001003734b7 -[TCocoaApplication run] + 71
11 com.idimager.idimagersu 0x000000010037378a COCOAINT$_$TCOCOAWIDGETSET_$__$$_APPRUN$TAPPLICATIONMAINLOOP + 106
12 com.idimager.idimagersu 0x0000000100066607 FORMS$_$TAPPLICATION_$__$$_RUN + 95
13 com.idimager.idimagersu 0x0000000100001c28 P$IDIMAGERSU_$$_MAIN + 1424
[edit hert; truncated the Apple Report to the relevant part]
Sigi
Post by Sigi »
Interesting - seems I am not alone. It worked perfectly in V5. I have not changed anything.
This should be resolved in build 3562. Can you confirm this? Thank you
Sigi
Post by Sigi »
Yes, it works. I can confirm. Building thumbnails right now and no crash.
