Path in file names
Username
Path in file names
Post by Username »
First release os V6 public beta:
The naming of downloaded jpegs still contain the full source path instead of it's name only.
_Volumes_filmstaden_Foto_Fotografier Nikon NEF - Original_2020_01_10__ACT6341.NEF.jpg
Should be:
PSO 6 on Windows Server 2022
- I'm the user
Re: Path in file names
I could not reproduce this before, until I realized that you are using the webservice with a database using macOS references.
The beta setup file was updated. Hopefully you get the correct file names now
Username
Post by Username »
Unfortunately it's still show the same problem.
I downloaded the linked update and installed it.
Configured and tried both a download as well as over email, but they both did use the path as filename.
- I'm the user
A new update was uploaded. The only fix is (again) to return the filename for a macOS (POSIX) formatted file names in the database
Username
Re: Path in file names [resolved]
Post by Username »
Works great now!
- I'm the user
