PostgreSQL version on MacOSX
Th0mc
Post by Th0mc »
Hi all,
I'm trying to install PostgreSQL for Photo Supreme Server.
Installing PostgreSQL with the official script, I had troubles with SCRAM encryption for Photo Surpreme (not supported)?
So In installed it via Homebrew and now I have the following message when I try to connect Photo Supreme to the database :
Your PostgreSQL version is "PostgreSQL 13.1 on x86_64-darwin19.6.0, compiled by Apple clang version 12.0.0 (clang-1200.0.32.27), 64-bit" and this version is not supported.
Don't know what to do :(
Thanks in advance for any help
Re: PostgreSQL version on MacOSX
A warm welcome to the forum. This message means that PostgreSQL version 13 is not supported. Psu V5 supports up to v12.
Also follow the configuration settings from the instructions?
https://manualsu.idimager.com/version5/ ... upreme.pdf
