Tag Intersections
Dismayed
Tag Intersections
Post by Dismayed »
Is there a way to select the intersection of tags in the Online Viewer? I'd like to view, for example, photos with two people that I've tagged. I had expected that I could select multiple tags by using the ctrl key and mouse, but that doesn't appear to work.
~ Will Rogers
Re: Tag Intersections
That is currently not possible. PSO is not developed with "cataloging" in mind, but developed to allow others to access and use your catalog. In other words: PSO is not a replacement for PSU for an add-on.
Visitors can, however, find all intersected images using the search box. For instance James+SImon gives all images that have the words James AND Simon in them.
Tip; the search box in PSO offers identical features as the search box in PSU. The search box, and how to use it "simple" or "advanced" is described in the Searching manual.
Dismayed
Post by Dismayed »
Thank you. Search should work well.
~ Will Rogers
