Copy to folder commands
Post by Stephen »
I hope everybody is well during this crazy time?
Perhaps someone could please refresh my memory since I set this up. For some (strange) reason I have clicked resize in my standard export setting. Was that so that meta data is exported (important)? However, I see another tab for that function.
My goal to to export in maximum quality and keep the meta data settings as selected below the window shown.
Thanks in advance and a Happy New Year
Photo SupremeScreenSnapz237.jpg (154.09 KiB) Viewed 2843 times
Re: Copy to folder commands
Hi Stephen, when Sizing is unchecked then PSU will send the original file, and hence no changes can be made. If you want to send out the file with changes then you should tock the "Sizing" box. To keep the original file size then select resize method "Keep Original Size"
PS. Wow, that's an old version of Photo Supreme :)
Post by Stephen »
Thanks, but what actually happens to the image? Is there any quality change? I can see that the file gets considerably smaller.
Yes, it's version 3.3.0
I bought v. 4 but had problems with the font size on my machine, so I re-installed v. 3
Post by Stephen »
Could I send you two files for comparison by dropbox please? I got stranded in South America with the Covid scare and cannot obtain a good monitor here. I would appreciate if you could pixel peep for me please.
