I would like to view the Expression Media People XMP data for my photos. Under the Info panel I created a new Custom Field of type “Macro Field” and used the macro “%xmp:expressionmedia:People”. The Expression Media People data shows up properly under the Info panel. However, under “Your Custom Fields” of the Details panel this data does not show up (other data using predefined fields do show up properly). Can you tell me how to fix this (or can this be made a predefined field)?
Re: Expression Media People
A macro field can be defined as almost anything, even scripts with the %code macro.
Try creating a new custom field of type “Predefined field”. The select the field from the drop down’s XMP section. I expect such fields to also be listed in the Image Details.
