I'm moving from another DAM so I'm having to revamp some of my metadata structure with the biggest change being in how I use star ratings and color labels. My old tool had 9 colors instead of 5 and it was easier to apply color labels vs star ratings so I used color labels to do my rating and some "actions" (like ones to print or upload) and didn't use star ratings at all. Since I now only have 5 color labels, I need to use the star ratings to cover everything. I was able to use some of PSU's functionality to do some of the things I previously did with colors like use the print tag under versions so I have some colors available to use.
So my curiosity is ... what kinds of things are y'all using color labels for? I'm looking for ideas because I'm a big believer in learning from other people instead of reinventing the wheel. I keep coming up with ideas but end up with ones that could be two colors at once. For example, if I used one color for things to print and another color for things to "publish" ... you could want to both print and publish one photo so that wouldn't work since you can only have one color label applied at a time.
I'd rather use the color labels for ratings since it's more visual so it's easier to see which ones are your good ones, but then it seems weird to make "2 star" mean "to print" or some other function not relating to it's quality.
Anyway, I'd love to hear how y'all are using color labels.
