DXO PhotoLab 3 DNG not how in PS
smgaetano
Post by smgaetano »
I have create some DNG file using last version of PhotoLab 3, when imported in PhotoSupreme they appear as black image.
Other DNG file from differente source are ok.
The same DNG image are show correctly in Finder and also in other sw like Affinity Photo.
Any idea.
Tanks
Re: DXO PhotoLab 3 DNG not how in PS
A warm welcome to the forum. Make sure that when creating a DNG file that you include a full size preview in the file.
I have PhotoLab 2.3.2 and, although I never normally export to DNG, I've just exported a few and they show up fine in Photo Supreme.
There is no setting to include a preview or exclude a preview in PhotoLab 2, so unless they've added one in version 3, perhaps they have introduced a bug?
As a workaround, if you 'version' your original file with the DNG within Photo Supreme, they you can use the original image to see what the DNG contains, even if you can't see the DNG (I do it regularly with Android DNGs, which PSU doesn't support).
However, are you clear why you're exporting to DNG rather than JPG or TIFF ? See also this thread.
