v5 timeline incomplete
ColinD
Post by ColinD »
Having completed the first catalog import into v5 the new folders are not showing in TIMELINE. They do appear in FOLDERS. Also there is a timeline entry for 1899/1899-12/1899-12-30 containing 22 tif or jpg images from various dates up to yesterday.
Win-10 1903 build 18362.388 64-bit
Re: v5 timeline incomplete
You probably closed the application while the import was still running.
Try “Tools-Read metadata for out of sync images” (off the top of my head, wording may differ slightly) from the hamburger menu.
ColinD
Post by ColinD »
Thanks Hert, that did the trick. In v4 the import progress bar remained clearly visible whereas in v5 it is harder to see so I must have shutdown thinking it was done.
