Slooooooow
jsrunnels
Slooooooow
Post by jsrunnels »
Every time I make a change to multiple images (for instance, adding a bunch of images to a new category or renaming a category), PSu pretty much slows to a halt while it synchronizes the changes. I am working with a small number of photos ATM (<2000) and it will take well over 5 minutes (often much more) and heavy computing (as evidenced by my fan whirring) to make each change. I can't do anything until the "Synchronize Service" is complete. This behavior is the same regardless of whether I have "Store metadata to database only" selected or not. I am on a MacBookPro that is less than a year old, running Mojave. It really shouldn't be a limitation of my machine. I am not running any other significant applications at the time
Is this normal behavior?? This just does not seem workable. I can't believe anyone else is experiencing this and is okay with it. Media Pro would do these types of maneuvers in a flash. I have to believe I am doing something really really wrong or have something set wrong.
Anyone have any insight?
Re: Slooooooow
Synchronization takes place in a background process and you don’t have to wait for that to finish.
Also, keep all the sync settings at their default (there’s a button to rest all sync settings to default).
Disable auto-sync (the top setting) if you don’t want to sync after changes.
Re: Slooooooow
Are your images kept on the same machine or are they stored elsewhere on the LAN, maybe access speed is contributing ?
