geotagging still does not work
amartel
Post by amartel »
As with the previous version, I can't set coordinates directly from the map because Right click doesn't display the contextual menu with search and 'set marker' option) :-(
OS: mac os 10.14.6 FRENCH
Photo Supreme: v5 server PostgreSQL
Geocoding API is installed and is working (map is displayed without warning, reverse lookup is OK)
The attached file shows a screen shot when doing a right click (as you can see, the only option displayed is "Reload").
Can someone give me some advice or anything else to find a way to resolve this problem (or a workaround) ???
Regards,
Arnaud
Re: PS v5 : geotagging still does not work
Hi Arnaud, this is a limitation of the Browser component on macOS. It doesn’t notify the application that the right mouse was clicked. This used to work until one of the macOS updates broke it. I always hoped/assumed Apple would fix that shortly, but apparently they don’t.
I’ll try it on Catalina later and if it still doesn’t work there, I’ll come up with a workaround very shortly.
Thank you for your patience.
amartel
Post by amartel »
Thank's a lot for your quick answer and I understand now where is the problem.
I'll wait and hope goods news from apple (but a workaround will be very helpful too ;-) )
Regards,
Arnaud
amartel
Post by amartel »
I just downloaded build 2401 and, now, geotagging... works again!!!
Thank's a lot for this workaround. That's perfect!
rfcat
Post by rfcat »
Assumption I have to re-install something to get GEO tagging to work in V5?
Ian
Found the answer in the help file.
Ian M
