Navigation with key tab doesn't work
julienhgr
Post by julienhgr »
I like to use my keybord to navigate in a screen. It's more easy and fast to use key tab for exemple.
But in screen about création label, key tab doesn't work correctly.
It's the same for you ? How to create a new label (and attach it to a parent label) only with keyword key (not the mouse) ?
Thank you so much for your help.
Julien
Re: Navigation with key tab doesn't work
Just checked it and works fine here.
  • Select the parent catalog label
  • Press Insert key on the keyword
julienhgr
Post by julienhgr »
Hello Hert, thank you so much for your answer.
I am using french version of PSU.
I will try to explain the bug with screen shot and an exemple :
exemple tab key.png (337.16 KiB) Viewed 1617 times
Thank you!
Julien
