Error on Forward Lookup in GEO Tagging
Paul Harris
Post by Paul Harris »
I have updated my Google Maps API and enabled the Javascript and Geotagging APIs. Everything, including Reverse Lookup works fine, except Forward Lookup returns an error:
Error: This API project is not authorized to use this API
Status: REQUEST_DENIED
Same message when I try to retrieve altitude. Do I need additional APIs?
Since I don't have time to go to Google Programming School, can anyone surmise why I am getting this error?
Much appreciated,
Paul
Re: Error on Forward Lookup in GEO Tagging
Make sure that your Google API key has the Elevation API configured.
Paul Harris
Thanks, Hert, that has the Altitude Import working, but I can't seem to find what is preventing me from doing a Forward Lookup :?
What Services do your have added now to your Google API key?
You should have:
1. Geocoding API
2. Maps Javascript API
3. Maps Elevation API
Paul Harris
Yes, those are the three that I have enabled. But when I do a straight Lookup I get:
Error: This IP, site or mobile application is not authorized to use this API key. Request received from IP address 104.190.227.110 with empty referer
Check the restrictions of your Google API key and make sure that you either restrict it with IP address and not with a HTTP-referrer.
(Credentials, click the edit pen icon, Application Restrictions)
Paul Harris
That seems to have done it.
Thanks, Hert
Best,
Paul
