Output (Sharing) question
mckeephoto
Post by mckeephoto »
This is probably a newbie question but I can't seem to figure this out.
I am attempting to select a few tiff images in a portfolio and output them as smaller jpgs in a new folder to share with a client.
However, I keep getting tiffs in stead of JPGs.
Here's what I have so far:
1. select images
2. go to Share>manage>Folder Transfer
3. click + to set up a new transfer profile
4. Location - select a folder
5. Sizing - seems self explanitory
6. File Naming
%FileName
I haven't messed with the other settings in there, such as Catalog Settings, Caption sig, etc.
The original file names are mckee_20160309_709 Master.tif I end up with mckee_20160309_709 Master.jpg.tif
Why am I not getting jpgs?
The tiffs are 8 bit, layered files.
Bonus question: is there a way to remove "Master" from the file name automatically in the sharing recipe?
Thanks!
Re: Output (Sharing) question
Hi Matt,
In the rename rule, click the hamburger menu next to the file name sample.
There click "Edit as Text"
Change it into %FileName.jpg (remove %FileExtension)
Click OK
To remove Master:
1. Click on % FileName
2. Select "Replace Text Part"
3. Replace Master with nothing
Here's the full rule as text, you can copy/paste it to the Edit as Text option
mckeephoto
Thank you, Hert!
It worked like a charm!
