I have been climbing the learning curve to Photo Supreme after using Media Pro for 15 years.
I have multiple formats that I would like to be able to export from the database to a folder as jpegs.
Export to folder does change the .psd to a .jpg.
The 16bit Tiff does change to 8bit, but there is no setting to change it to a jpg.
I must be missing it somewhere?
Export tiff, psd, etc to JPG -Where is the jpg settings?
- Contact:
Re: Export tiff, psd, etc to JPG -Where is the jpg settings?
It should be sufficient to hard enter the .jpg extension in the file name. PSU will then know that it needs to write a JPG
- Contact:
Thanks, Hert. I will give it a try.
