Altitude displayed differently
kalain
Post by kalain »
Here is altitude displayed from GeoTag panel (456.03 mtr) :
screen copy04-09-2018-19.02.59.jpg (11.89 KiB) Viewed 1409 times
and then (same image) from Infos panel :
screen copy04-09-2018-19.02.30.jpg (6.21 KiB) Viewed 1409 times
Looks like there is some display improvements to do here ?
Re: Altitude displayed differently
PSU shows you what is available in the XMP of that field (no formatting takes place). The GPSAltitude field contains a rationale. In the next update this will be fixed and it will then re-format this particular field for better display.
Thank you
