Floating Viewer and two monitors
Brent M
Post by Brent M »
I see several posts about a "Floating Viewer". I am looking for a way to take advantage of two monitors.
What is a "Floating Viewer" and how do I get it up. What other advice do you have for using two monitors.
Brent
Re: Floating Viewer and two monitors
Click Preview on a Thumbnail, press Enter or Double click a thumbnail and a floating window will appear with a zoomable image.
Post by jstartin »
Look into preferences:
You probably want the third option, but I have only a single monitor so can't use it myself.
HaraldE
Post by HaraldE »
Morning,
I use Second Monitor all the time when I have photos to show to people.
Then I connect my PC to my large TV and use it as Second Monitor
Regards, Harald
