How to transition from PS v2 to PS Server v3?
satchid
Post by satchid »
We have been using Photo Supreme v2, single user version and would like to update to Photo Supreme v3 server edition. I've download PostGreSQL and installed it along with PS v3 Server Edition.
I am unable to figure out how to import my existing cat.db file into the new server version of PS. I even tried a backup in v2, and a restore (of the backup folder) in v3 but that did not work.
I read through the available PS manuals but do not find steps to import an existing cat.db file.
Any support/advice is appreciated.
HCS
Re: How to transition from PS v2 to PS Server v3?
Post by HCS »
satchid wrote: 16 Sep 17 6:03 Hi,
Hi, i believe at this moment right above your post (will change in a matter of time), the thread that holds the conversion app to migrate from single user to Server version: viewtopic.php?f=57&t=23417&sid=a54d2d34 ... 533395fc83
Check with Hert first whether you can just use it. Also, make sure of backups!
