Updates: Where can I download them from?
bobmcswain
Post by bobmcswain »
I'm having the "no webupdater found" issue. A forum topic says the solution is to just download upload. I can not find where the updates are stored on the website.
Preston B
Re: Updates: Where can I download them from?
Post by Preston B »
Go to the IDImager Control panel at https://cp.idimager.com
Log in and then select your version of PSu for download. Install the application, and you should be good to go.
I have no idea why you're getting the "No web updater found" message. This sounds like one for Hert.
--P
Preston Birdwell
Columbia, CA
