Flickr uploads failing
Post by snowman1 »
Is it just me that has been having PSU to flickr uploads failing recently? It displays a variety of symptoms. A hang is common. An error message is usually emitted at some point, saying something like it couldn't find the picture (sorry I didn't copy the full text). Sometimes the pictures get to flickr anyway, sometimes they don't. One time it was every other picture that failed... Is it just me?
If it is just me I will try to capture more info.
KeesdH
Re: Flickr uploads failing
Post by KeesdH »
I have the same issue. Same symptoms. Lets file an error in Mantis.
Lou_Salkind
Post by Lou_Salkind »
I filed a similar bug report in mantis several days ago.
Post by snowman1 »
Hi Lou
Strange, I can't see that in Mantis?
DirkS
Post by DirkS »
snowman1 wrote:Hi Lou
http://mantis.idimager.com/view.php?id=2925
Post by snowman1 »
Thanks Dirk. No idea why I couldn't see that on a straight search, must have had the filters set wrong or something. [Edit - yeah - it was the project field up at the top right. I always fall for that one]
I have added my findings to that issue. Keesdh, you might want to have a look and maybe add any useful info you might have noticed.
Cheers
