After installing the new version, the import module gives error messages: "cannot create ampty directory (0)"
Is there a simple solution, or should I report a bug?
Tom
(3.0.3.2064 64bit) import failure
Re: (3.0.3.2064 64bit) import failure
Apparently this is fixed in 2066. See http://www.idimager.com/WP/?page_id=1374; first line below 'fixed in this version'
Thanks DirkS, it is fixed indeed in 2066.
Tom
Tom
