Catalog location on my hard drive
geraldmarsden
Post by geraldmarsden »
I would like to make copies of my catalog from time to time on a second hard drive. Where in my system is the catalog located by default? Thanks
Re: Catalog location on my hard drive
You can check by going to Preferences -> General Settings, then checking the box "show a login dialog on startup", then restarting the program. The location will be shown in the login dialog.
In Windows, by default they go in C:\Users\UserName\AppData\Local\IDimager Systems, Inc
geraldmarsden
Thanks.
Post by jstartin »
If you use the item on the Tools menu "Backup Photo Supreme Data" you will be able to copy the catalog to a drive and folder of your choice without having to worry about where the working copy is kept, or to mess about with folders that are normally hidden from view.
geraldmarsden
Thanks, Jstartin, that's helpful as well.
