V3: external Edit with DxO and C1
Nordlicht
Post by Nordlicht »
Hello, I've upgradet to V3. Are external edits with DxO and C1 automaticly picked up from PS v3 or is there the need to manually rebuild the previews?
Nordlicht
HCS
Re: V3: external Edit with DxO and C1
Post by HCS »
It seems you need to rebuild the thumbnails. It's something easily tried. Just pick one with radical processing and rebuild the thumbnail from the menu. You'll see it reflects the edits. You may need to set the preference to "Approximate" in the file handling preferences though.
The first time you need to rebuild the thumbnails. Also, if your images have C1, and Dxo and LR edits (some people tried them all and have the dop and cos and CRS schema without realizing it) then make sure that you disable those tools that you no longer use and keep only your leading editor enabled.
Once you make changes and the tool writes the updates to the file, either as cos or dop or CRS in XMP then those changes will typically be picked up automatically.
