displaying version placeholder in thumbnail info
doug_w
Post by doug_w »
Can the version placeholder be displayed in the custom thumbnail info? If so, what's the code?
Thanks.
photography.dougwieringa.com
Re: displaying version placeholder in thumbnail info
Hi Doug,
For the next update (1031) I've added a macro command for this; %CatalogPlaceholderList
Also...
Keep in mind that one image can be assigned to multiple version placeholders.
For now you can achieve the same with a script (just copy/paste the entire script to a custom thumb info line).
%code
var
  ACatItem, AMain: TCatalogItem;
  APhs: TCatalogPlaceHolders;
  i: Integer;
begin
  result := '';
  AMain := TCatalogItem.Create(nil);
  try
    if Catalog.FindVersionImage(ImageItem, ACatItem) then
    begin
      if Catalog.FindMainVersionForItem(ACatItem, AMain) then
      begin
        APhs := TCatalogPlaceHolders.Create(TCatalogPlaceHolder, '');
        try
          Catalog.EnumPlaceHoldersForVersionInMain(AMain, ACatItem, APhs);
          for i := 0 to APhs.Count - 1 do
            result := result + iif(i = 0, '', ',') + APhs.Items[i].PlaceHolder;
        finally
          APhs.Free;
        end;
      end;
    end;
  finally
    AMain.Free;
    ACatItem.Free;
  end;
end;
%/code
Hope that helps
doug_w
Post by doug_w »
Perfect. Thanks!
