After installing v2 DNGCopyHandler fails
HCJ
Post by HCJ »
I have intalled PSv2 and converted my catalog using v2. Most things seem to work fine. I tried to import images and got the message box with -- Script Error Unknown member identifier: 'SkipExisting'. Source position: 93,29.
This appears to be a problem in the DNGCopyHandler script. Nothing will import and I am stuck. Is this a known problem ? Help would be appreciated.
HJ
Re: After installing v2 DNGCopyHandler fails
Post by weidmic »
HJ,
Take a look here.
It has been reported already and it is solved...
http://bugs.idimager.com/view.php?id=1907
