Would like Batcher to remember last browsed location
danaltick
Post by danaltick »
It would be nice if the Batcher would remember the last location browsed to or when opening the browser if it would open it to the current selected location from the dropdown.
Dan
Re: Would like Batcher to remember last browsed location
I've added this.
Btw; I'd like to point out that you can log feature requests in Mantis;
http://bugs.idimager.com
danaltick
Post by danaltick »
Hert,
Thanks. Ok, I will do that from now on. Thought mantis was strictly for bugs.
Dan
I want everything collected in one repository. And at the same time, I don't like how this forum gets cluttered with off-topic replies.
The forum must become a more helpful resource for working with PSU. The overall quality of the forum should go up when it comes to working with *existing* PSU features.
danaltick
Post by danaltick »
I totally agree.
Dan
danaltick
Post by danaltick »
Hert,
Got the new update with the Batcher "Save as..." and watermark alpha channel fix. The both work great. Thanks so much.
Did you forget this fix though? The browser is still opening for me at the "Computer" top level folder every time.
Dan
Dan,
This should be in... You mean the dialog that appears when selecting a output folder, right (that is where I changed this). It uses the entry that is currently selected. Fr new batches it will default o top node.
danaltick
Post by danaltick »
Hert,
Yes, I do mean the browser dialog that opens when you select either the hard drive icon or the "Choose selecetion" from the folder dropdown. However, in both cases for me the dialog always open to the top level "Computer" folder on Windows7, even for currently selected Batches that have an output folder.
Dan
Dan,
Got it now.
danaltick
Post by danaltick »
Hert,
Works great with the new update.
Dan
