Adjust & Save As no file name
Desinnz
Post by Desinnz »
Hi Hert
when using the edit tools on an image in "adjust" after cropping or any other adjustments I select "Save As" and the file name box comes up blank and there is no indication as to the file name that Im working on that I can see to copy from.
Also it doesn't seem possible to have "info" and "Adjust" open at the same time so cant copy the file name from there.
Is the blank file name box at Save As by design ??
Cheers
Des
Melbourne
Re: Adjust & Save As no file name
Post by tstoddard »
I have raised this issue before but I haven't entered a feature request in Mantis because I'm not sure exactly what to ask for. I guess we could start by asking for the Save As dialog to be populated with the name of the file currently selected. I have also suggested that the file name be displayed somewhere else on the screen when the file is being adjusted (edited). There is certainly room to do so.
Thanks for bringing this issue up again.
Desinnz
Post by Desinnz »
Hi Tom
I did find your post about the same issue and saw that you didn't get a response -
Des
Did this change in the latest update (108)?
Post by tstoddard »
Yes, Hert. Now the file name does populate the file name field in the save as dialog. Thank you! I still think it would be helpful for the file name to appear somewhere on the screen at all times but I can live without that.
Desinnz
Post by Desinnz »
Thank you Hert !!!
Des
