Incorrect dates on some files
danaltick
Post by danaltick »
Some of my images have incorrect dates when sorting or filtering by date, yet their exif date-time-original and date-time-digitized are correct. Not sure how to correct the problem.
Dan
Re: Incorrect dates on some files
PSU uses XMP and most likely your XMP is not complete; more particularly, I suspect that the tool that created the first XMP block in the file didn't convert the Exif to XMP. Use this script to correct this. Try it on a small set first
http://forum.idimager.com/viewtopic.php?f=57&t=22450
danaltick
Post by danaltick »
Hert,
That did the trick. Auto-sync worked fine too. My copyright info did not get wiped out.
Dan
