Not shure if bug - errors because of color profiles
Menace
Post by Menace »
I am not sure, if it is a bug or not, so I write first here.
Workflow:
1. Take images with Canon Mark III
2. Konvert with Capture One Pro 7 (--> 8 Bit jpg with camera color profile inside)
3. Import folder to photo supreme 64
4. Get Error: Color management found erros while "sharing": Color management found error in one or more your existing color profiles. Read from memory error. Got 127162 bytes, block should be of 215622 bytes"
I get no error with Adobe Bridge CS4, Photo Shop, Daminion and Picasa photo viewer.
Re: Not shure if bug - errors because of color profiles
Menace,
Can you send me an example JPG as created with C1?
Thank you
Menace
Post by Menace »
I am currently on another computer. There I've got no "error message", even with the same file. I try it tomorrow again (with the problem computer).
Regards,
Menace.
Do both computers run the same version? And the same architecture (32/64bits)?
Thank you
Menace
Post by Menace »
Same version (Win 7 64; actual version .74; same architecture (64 bits)).
Both PC uses Spider Monitor color calibration.
Different:
RAM: no Problem PC: 4 GB; Problem PC: 12 GB
Graphic-Card: No Program ATI 5770; Problem PC: 6850
Edit: Sorry: Both PC have the problem, if I start "Display Color Managment".
IDimager wrote:Can you send me an example JPG as created with C1?
Can you provide me with an example so I can have a look at this issue?
Thank you
