Drag-drop not working in PSU 1.5
Tom
Post by Tom »
Drag-and-drop (namely Alt+drag and drop) does not work in 1.5. I tried it with IrfanView, Lightroom and Photoshop. They all give different errors, which main message is that the file(s) were not found. If you confirm this, I would report it to mantis. Or is it only my specific problem, which I should find the cure for.
Toomas
Re: Drag-drop not working in PSU 1.5
Even unconfirmed I recommend to report in Mantis. If someone in the future runs into the same issue then yours will turn up as well.
I can't try it right now, but relevant info is if you're running the 32 or 64 bits or Mac version. Alt+Deag is not yet implemented for Mac
Menace
Post by Menace »
Have your folder special signs like ä, ü, ...?
Tom
Post by Tom »
It is 32 bit, windows 7. No special characters used in the folder. The feature worked in previous version. I will report to Mantis.
Toomas
I was able to reproduce this and fixed it for the next update
Tom
Post by Tom »
It works now after last upgrade. Great.
Toomas
