Hi all,
I've been exploring Photo Supreme and so far it's mostly with relief that most of the functionality of IDI5 is there but simplified with far less scary pitfalls.
One thing I haven't figured out yet and just wanted to check if I'm missing something:
- sometimes I need to add 2 separate logos to photos when I batch export them e.g. for creating a ppt slideshow, need to add our logo and our parent organization logo. I found the watermark function in the batcher, but there doesn't seem to be any option to add two watermarks any more?
Monica
adding 2 separate logos (watermark) in batch?
Re: adding 2 separate logos (watermark) in batch?
Hi Monica,
I tried this here. You can add the same effect several times. But there is a bug. When you add the same effect twice, they will be considered the same, which is why you get the same details when you edit either of the duplicate effects. I now fixed that for the next updateAnahataAV wrote:- sometimes I need to add 2 separate logos to photos when I batch export them e.g. for creating a ppt slideshow, need to add our logo and our parent organization logo. I found the watermark function in the batcher, but there doesn't seem to be any option to add two watermarks any more?
Great! I'll look forward to the next update.
Monica
Monica
