Hello together,
is it possible to generate own templates and layout for printing images?
Best regards
Georg
Photosupreme and Printing
Re: Photosupreme and Printing
Georg, no you can't do that with PSU. There are templates available for the most common print formats. If you already have a preferred IDimagerV5 template then you could try to add it to PSU, by copying the template file to the Resources folder. I expect that PSU will be able to read it, not sure though
The next feature cutted down from IDI.
Now printing is less flexible than in most other DAM applications!
I AM DEEPLY DISAPPOINTED concerning your new software!!!!!!!!!!!
