Is there any way to change the date format that's displayed on the thumbs. Right now it is, as an example, 25-8-12 format but I would prefer either 2012-08-25 or 08/25/2012.
Larry
Date format
Re: Date format
Yes this can be made exactly as you like - Write some code here:
View > Custom thumb Info
In the right of the field click the triangle to get help.
2012-08-25 goes like this:
You may have to reopen the programme to see the change.
%yyyy-%mm-%dd
W7/64bit, IDimager V5 ProSL
Re: Date format
Thanks, Lars. Seems so simple. For some reason I never noticed the View button. Need to have my eyes checked.
Larry
Larry
