I'm running a 13" MacBook and so may screen is small. IDiNE opens maximized and I can't find a way to drag the horizontal bottom up to make smaller. As it is now, my icons at the bottom of the screen partially cover the toolbar commands.
I'm new to Mac so there may be an easy adjustment, but I haven't found it.
I run IDI Pro on a Windows computer but recently bought this MacBook since we use Apples at work. I'm looking for an image program that can filter and search on keywords and IPTC data and was glad to find this beta.
Larry
Adjusting screen
Re: Adjusting screen
Larry,
Does it help if you click the green + icon to maximize the form for the screen. This is the + icon that is part of every Mac application title bar.
No it doesn't. The dock icons still cover part of bottom of IDI.
I've tried to manually resize but am unable to do that either.
Larry
Larry
Hi Larry,
A new release has just been released. I think (and sincerely hope
) this will fix this problem as well.
Brian
Brian
I think it's better but the top of the icons on the dock still go into the toolbar at the bottom of IDI and I can't manually resize the screen.
Larry
Larry
Can you pls post a screen shot Larry? Shortcut is Cmd+Ctrl+Shift+3.
Thx,
Brian
Thx,
Brian
You can see at the bottom the dock icons go into the toolbar.
Larry
Larry
- Screen Shot 2012-02-27.png (284.98 KiB) Viewed 13399 times
Larry, with the next beta, the minimum size of the application is made smaller so it should better fit your screen resolution
Thanks. Installed latest update and the screen is fine. Just one question. The corner to grab for manual resizing is a gray triangle with diagonal lines. Should it be that? I think I've seen just diagonal lines in other apps.Hert/IDimager wrote:Larry, with the next beta, the minimum size of the application is made smaller so it should better fit your screen resolution
Larry
