Redating from file name
AlainB
Re: Redating from file name
Post by AlainB »
RobiWan wrote: 28 Feb 24 13:56
AlainB wrote: 28 Feb 24 13:43 G8DHE suggestion was for Window.
No, his suggestion was OS Independent. You can put in this menu each App is OS executable.
Good for you if you can put exiftool (located in /usr/local/bin/exiftool) namely a perl script in the PSu menu.
I can put in the PSu menu what Apple calls an Application (like DXO PhotoLab or TextEdit) but not exiftool.
But you can sure do better
AlainB wrote: 29 Feb 24 9:51 Good for you if you can put
Why do you want to add it as an icon where you can achieve exactly the same thing by starting Terminal?
I mean, I've written it before. There are no advantages to having such a tool hanging there as an icon
