Unable to reduce page size
MickC
Re: Unable to reduce page size
Post by MickC »
Yes, it only happened after the upgrade to V6 and although it has been a small irritation it only became an issue today when I tried to use the search bar (top right) and I couldn’t see the words I typed in properly.
Hovering the mouse over the menu bar has no effect either.
Anyway, I appreciate your efforts. All the best Hert
LittleRoundBox
Post by LittleRoundBox »
I had the same problem. I am using High Sierra and am unable to make the PS window smaller and the top of the PS window is under the OSX Menu bar. I am using 7.3.0.4459. the workaround I am using is through OSX mission control where I am able to take the full-screen view and make it its own desktop. When doing this the PS application is fullscreen and the OSX menubar hides so I can get to the top of the window. I would prefer full window controls but for now, this is how I am doing it. Hope this helps others.
