Type filter shows only "All JPG" in v7
Re: Type filter shows only "All JPG" in v7
In the next build that setting will return. Make sure to set that to your preferred setting again.
That's a HUGE relief! Thank you!!!
Much looking forward to that update...
simato73
Post by simato73 »
With build 4303 the old options for Versioning have been reintroduced and all has gone back to the way it was - this is great.
Thank you Hert!
Simone
Yes, and the versioning menus are now even better. Via right-click on the mini tabs you can directly cascade metadata. That's fantastic!
One drawback:
The wrong tabs are being selected for the different versions, see here: http://forum.idimager.com/viewtopic.php?t=29973
But I am sure, Hert is working on it.
I like this new build very much.
THANK YOU !!!
