V7: Folder with versions shows always main version
tumirnix
Post by tumirnix »
after the (smooth) upgrade of PSU from version 6 to 7 I have the following issue:
I have some folders where I place versions for further editing. When I enter such a folder, PSU shows me always initially the main version (from another folder). That's a bit cumbersome, because I have to switch always the version before I can open the editor.
Is there a chance to switch it back to PSU 6 behavior?
Thanks in advance
Martin
Re: V7: Folder with versions shows always main version
The "Version Set Display" preference setting (Preferences -> Catalog -> Versions) has returned in build 4303.
You can download this update from the Control Panel
tumirnix
Post by tumirnix »
I'm a bit confused. Today got the version 7.1.0.4306, does this contain your mentioned feature?
I found in the "Version Set display" field, which has 2 options:
  • As a Set in Categories
  • Always together as a Set
Screenshot of my PSU 7 preferences
I wonder which one would show me the image in the current folder on top (and not the main version).
Thanks in advance
Martin
"As a set in categories"
tumirnix
Post by tumirnix »
thanks for the answer. I have the settings "As a set in categories" and it seems that there is another bug.
When I enter the folder, I see
When entering the folder
The images of this folder are shown, but the main version is marked.
When I click for the first image on the first version, it changes to:
After clicking on the (1) of the first image
The image and capture is not changed.
When I click again on the main version for the first image, the result is:
After clicking on the main version of the first image
This is the main version with the corresponding file name.
Best regards
Martin
great that this version display option has returned. As you know I have much been looking forward to this. Very nice also, that you introduced the hamburger menu with more options how to manage the versions and the right-click menu on the tabs. Also, cycling through versions is now much faster. Excellent!
But Martin is right, when he noticed that, when the versions are displayed side-by side in folder view, the tab is always highlighted as the main version, and not as the tab the version actually refers too.
It should look like this:
Unfortunately, it looks like this:
So - although the correct versions are shown side-by-side (in "As Set In Categories"), the wrong version tab is displayed for each single version.
Sorry - that I did not notice this before.
And, of course, which particular tab is shown is really important, when you select from which tab to cascade, change placeholders, etc., etc....
Again, really sorry that I overlooked that. I was just too busy.
