Public Beta for Photo Supreme Online
Re: Public Beta for Photo Supreme Online
The beta is silently updated every now and then. Progress is mostly in the backend. Make sure to install the software as explained in the PDF in the opening post here.
If you become an active user of the PSO beta then please report here.
I just installed the PSO software. It works, but I don't have much catalogued yet, so more feedback will come in the coming weeks.
~ Will Rogers
~ Will Rogers
That's great! Looking forward to your feedback
Sorry for a longer time of absence.
Anyway, the naming of downloaded jpegs still contain the full source path instead of it's name only.
_Volumes_filmstaden_Foto_Fotografier Nikon NEF - Original_2020_01_10__ACT6341.NEF.jpg
Should be:
Should be:
PSO 6 on Windows Server 2022
- I'm the user
- I'm the user
I just installed this on my server after upgrading to PS 6.
If I open a browser on my LAN to 192.168.1.101:8081 then it immediately redirects to 192.168.1.101:8081/#/. At the bottom of the browser window is a line "The service is currently unavailable. Please try again later."
The firewall shows that Photo Supreme Web Service module is allowed through Domain/Private/Public. The service is running.
Any ideas on what to look at?
[edit] If I remote into my server, I can run PSO. It just cannot communicate with the rest of the LAN.
[edit2] I initially neglected to change the Web Config API Url to 192.168.1.101 from localhost. Working now.
Gordon Currie
Photo Supreme 2024 PostgreSQL on Windows Server Essentials 2016
I can now see the Photo Supreme Online window, with a login box.
I tried to login with Photo Supreme user/passwords, but it seems to ONLY want postgres as the username.
error: Cannot load options; [FireDAC][Phys][pg][libpg] password authentication failed for user "postgres"
followed by
error: fail to handle API request (stage beforeExecution) [FireDAC][Phys][pg][libpg] password authentication failed for user "postgres"
followed by
Gordon Currie
You should enter your Photo Supreme username and password in the login page, not your PostgreSQL username and password.
But based on your error, it looks like you have not entered the correct PostgreSQL password in the configuration dialog. Please run through the configuration settings again and use the test button to test the connection to your database. You can find it in the Windows menu.
In the configuration, the PostgreSQL password is correct, as I can use the Test button and it reports a connection. On both main and thumbs database.
I enter the Photo Supreme User/password for that machine (not the PostgreSQL user/password).
Gordon Currie
Follow up - I rebooted the server and the authentication now works as designed.
I'll post more as soon as I use it more. Looks very useful here as we sometimes just want to review or display photos without using the full program.
I'm guessing that I can use ANY modern device with a browser to display? If so, that is even more useful, as I can use an iPhone or iPad for browsing images.
Gordon Currie
Great that you're up and running.
Yes you canI'm guessing that I can use ANY modern device with a browser to display? If so, that is even more useful, as I can use an iPhone or iPad for browsing images.
The installer was updated to support the recent changes and performance improvement...those benefits also apply to PSO.
Will be PSO eventually avalaible also for Single User Edition ?
The links to the beta PSO software have been updated to a V7 version.
Yes it would be nice to be able to use this from the Single User version, i,e, not using POSTgreSQL!
At present I use a Remote access method to my workstation when remote to identify images using the normal interface.
The single user edition uses SQLite as its database. And SQLite is a single user database. Having that as part of a shared solution, which PSO is, makes little sense.
