Laptop as primary PSU home?
Re: Laptop as primary PSU home?
Post by Mike Buckley »
DirkS wrote:off-line mode
In Photo Supreme, it's called Travel Mode.
DirkS
Post by DirkS »
It's obvious I don't have a use for it (my main computer is a notebook with an SSD + 1TB internal drive; it always goes where I go :) )
BTW: a year ago even Hert still called it offline mode http://forum.idimager.com/viewtopic.php?t=22934
Gr.
Dirk.
Good to hear from you, Dirk!
DirkS wrote: BTW: a year ago even Hert still called it offline mode http://forum.idimager.com/viewtopic.php?t=22934
I'm not surprised. Don't get me going on the subject of inaccurate documentation of Supreme V2 that is acknowledged by Hert to be inaccurate.
A post on (any) forum is to be considered less accurate as time goes by and the older it gets ;) A year ago it was still called OFFLINE mode in Photo Supreme, in a release early 2014 the name was changed to TRAVEL mode. Someone who never uses this wouldn't have noticed.
@Mike, I read a lot of things and I can only wish that I remembered everything. Did you report any such inaccuracies to support? If so, can you point me to the support ticket in Mantis?
DirkS
Post by DirkS »
IDimager wrote:A year ago it was still called OFFLINE mode in Photo Supreme, in a release early 2014 the name was changed to TRAVEL mode. Someone who never uses this wouldn't have noticed.
Aha... that was while I was offline (but not travelling); living in the reedbeds of Norfolk ;)
Thanks Dirk & Mike - I've just read the Travel Mode description in the Cataloging Manual. This mode seems very useful, no matter how it's called.
My inquisitive mind still wonders: let's say I take my laptop on a trip and I don't have all my catalog images available (they might be on an external hard-disk, left home), but I want to import and catalog new photos. Can I sync the metadata only in these images? Do I need to activate the Travel Mode when only some of the image files are missing? Does PSU handle well missing (offline) image files in normal (online) mode, even when those share common labels with the online images?
I guess I could always create a brand new catalog on every trip and not worry about the Travel Mode - but I would personally do that only if:
1) there was a easy way to import the existing catalog structure from the master catalog (such that I could reuse my previous labels)
2) there was a straightforward (fast, reliable, supported) way to merge back the new catalog to the master catalog
lippe
Post by lippe »
You cannot import while in travel mode. If you disengage travel mode, you could import the images with different import settings to the notebook while on a trip. When back at home, relocate the images to the external hard disk and tell PSU to
However, i would enjoy my trip, and do the cataloging when I'm back at home. ;-)
IDimager wrote:@Mike, Did you report any such inaccuracies to support? If so, can you point me to the support ticket in Mantis?
I didn't report one set of inaccuracies because you publicly reported them to me. It was bad enough that I wasted my time due to known inaccuracies that had not been corrected. In that situation I shouldn't have to use even more of my time to report them in Mantis. If you're interested in correcting them, I'm referring to the search properties listed on pages 8 and 9 in the Search Manual that indicate use of uppercase letters when apparently mixed-case letters should be used.
Apparently you have some natural resistance against Mantis. Please don't waste any of your time, that's the last I would want.
Now you make up your own truth here because this was NOT a known inaccuracy. I wasn't even aware of this discrepancy between the software and the manual until you first made mention of it and I subsequently looked into your issue. And I didn't "report it to you", but I "confirmed your finding", there's a big difference. But apparently you expect that things are automatically corrected as soon as you mention it somewhere. At the same time you refuse to follow the outlined procedures to log a ticket for issues so that it won't be forgotten about and a change can be planned.
I don't know where the negativity comes from.
Ok, I've saved everyone's time (for the Search Bar issue, at least) - please see Mantis ticket 2446: http://bugs.idimager.com/view.php?id=2446
P.S.: Give me the source and I'll correct the Search manual too! :)
Back on topic (somewhat): Lippe, thanks for the clarifications. Your advice about enjoying the trips without worrying about cataloging might actually be the most valuable! An ideal pleasure trip should be so relaxing that one might even forget what a DAM system is... :)
