If I start editing Metadata in fields of the details view, PSU makes proposals out of a list of earlier entries in this field after typing the first 2-3 letters or numbers. If I don't select a text out of the proposal list, the box, in which I could select the text proposal remains on the screen as a dark gray box in the foreground of the screen at the position, where it popped up. Even if I scroll up or down in the detail window, the box remains there. Also after switching to another application (e.g. the browser), this box remains in the foreground. This repeats also for further metadata fields, so I will end up with lot of black boxes, which populate the details view and make it unusable. Only a restart of PSU clears these boxes.
Tagging of photos with this annoying behavior is a pain and close to unusable.
My configuration is:
MacOS Sequoia 15.0 and 15.1 (no change of behavior after update to 15.1)
MacBook Pro with M2 and 64 GB RAM
PSU build 2024.2.2.6668 (and earlier versions) - German language setting
