Instruction document: Workflow with Dynamic Collections
Here is a "pre release" guide on setting up a workflow with Photo Supreme using the Catalog Filter and Dynamic Collections. This guide will help you through the process. Remember, workflows are personal, so use this as a reference and choose the elements that best suit your needs.
https://manualsu.idimager.com/version9/ ... ctions.pdf
By the way, you'll need build 6593 or higher to import a Portfolio structure as mentioned in the instruction.
