[Security Alert]: Polyfill.io Issue for Google Maps Platform users
Bongo
Post by Bongo »
I received a notification from Google, which refers to the photo Supreme project. Do I or Hert have to do something?
29.06.24, 01:08
Hello Google Maps Platform Customer,
We're writing to let you know that a security issue may be affecting websites using specific third-party libraries (including polyfill.io).
What happened
We have become aware of a security issue that may be affecting websites using specific third-party libraries (including polyfill.io). This issue can sometimes redirect visitors away from the intended website without website owner knowledge or permission, or potentially cause other malicious behavior. Many of the Maps JavaScript API samples in the Developer Documentation previously included a polyfill.io script declaration. We have removed this from those samples. If you have used the Maps JavaScript API samples that contain this declaration, we recommend removing the declaration.
What to do
Please see below to learn how to take action, if needed:
Investigate your website: Check your website's code to see if you're loading any compromised libraries (including polyfill.io).
Remove or replace the code: If you find compromised libraries, consider:
Hosting a clean, secure version of the code yourself
Switching to an alternative library or provider
Removing the library if you don’t need it
Re-deploy your code through your regular process.
For your reference, attached is a list of your projects where we have detected Maps Javascript API usage. Please check all sites associated with these projects.
Regards, Bongo
Photo Supreme V2023 Single User Edition, Windows 11.
Re: [Security Alert]: Polyfill.io Issue for Google Maps Platform users
Google sent that warning to all Maps APU users as the Google samples on their website contained some code examples that included libraries that were served by the "once safe to use, but not anymore" polyfill.io domain.
PSU does not use libraries that are served from the polyfill.io domain.
Bongo
Post by Bongo »
Thanks Hert,
Then I don't have to worry.
Regards, Bongo
